1990 Honda CRX DX Auto. Trans. swap to Manual Trans.
Old Jan 21, 2021 | 04:29 AM
KFerrer's Avatar
Default 1990 Honda CRX DX Auto. Trans. swap to Manual Trans.
Hi everyone. I currently have two 1990 CRX DX models, one manual, and one auto. Both are the same year, same model, and same motor. I was wondering if someone could maybe give me some pointers on how to swap the engine from the automatic CRX, to the manual CRX. What would I need ahead of time to prepare for a swap, parts wise, tools wise, etc.? Any help is appreciated! )
Old Jan 21, 2021 | 01:00 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: 1990 Honda CRX DX Auto. Trans. swap to Manual Trans.
Are you only swapping the engine? If so, it will be a direct swap - no additional parts needed. Depending on how old some components are, it may be a good time to replace them while you have the engine and transmission separated. I'm thinking mainly of the clutch and the rear main seal (if it's leaking), but any other maintenance items like the timing belt, coolant hoses, etc. - now would be a good time.
Old Jan 21, 2021 | 01:50 PM
jlicrx's Avatar
be sure you use the engine wiring harness from the manual engine
Old Jan 23, 2021 | 07:30 PM
singlecamclan's Avatar
Tools:
•17 mm/14 mm for mounts and bellhousing
•12 mm/14mm (12 point socket) for clutch and fly wheel *blue lock tite when assembling the clutch and fly wheel *
And that’s the basic tool sizes to drop your d15
I’m not going to go over each individual bolt size so bring yo toolset.
Manual harness—— dpfi stock obd0 or Convert to obd1 mpfi
Cable shift linkages
rice a roni
23
Sep 30, 2022 02:12 AM
TypeR15
Aug 9, 2005 01:43 PM
bgoetz
10
Aug 29, 2004 09:27 PM
JonBoy
Feb 28, 2002 07:54 AM
