Suspension & Brakes Theory, alignment, spring rates....
Upgrade brakes
Old Jan 17, 2021 | 08:16 AM
SaltyBeaR25's Avatar
Default Upgrade brakes
Hey guys,
I have a 2000 Civic EX EJ model and I was wondering if a pair of spoon brake calipers will fit?
I search the web and I found out the EK’s front clip is the same as EJ’s until you get to the piles. I’m wanting to make sure before spending over 1k for them. Any information is greatly appreciated.
https://spoonusa.com/spoon-twin-bloc...p3-gd3-ge8-gk5
Old Jan 17, 2021 | 09:14 AM
EE2bitsk's Avatar
Default Re: Upgrade brakes
you’ll have to do mods to keep 4x100 which would include a spacer, mini cooper rotor iirc and an adapter for the calipers. or you can 5 lug swap and they bolt right up. also they may not clear your wheels depending on specs. search some more and you’ll find the info.
Old Jan 18, 2021 | 06:35 AM
I’ll most likely do a conversation to 5 lug to get it to fit right, but thank you for your feed back
Old Jan 18, 2021 | 03:10 PM
EE2bitsk's Avatar
there you go, and no problem. post a few pics!
Old Jan 20, 2021 | 07:49 AM
aw614's Avatar
10 Year Member
Loved
280mm mini cooper rotors and the Spoon calipers should be a direct fit without any spacers. With ITR pads, there is also no pad taper like on the Mini Cooper/ITR caliper combo
If you run the spoon rotor or redrilled prelude rotor, I think you need to put a 3mm spacer between the hub an the rotor.
00gs-r
Mar 20, 2007 06:36 AM
92egboost
Nov 24, 2006 06:40 PM
illuzi0nz
Jul 7, 2005 09:27 PM
3vilMonkey!
Oct 23, 2004 09:16 AM
JunIntegra
Oct 19, 2003 05:13 PM
