I'm suspecting a faulty pcm for a 2000 honda civic ex auto trans. D16y8 motor. The pcm I have is a A92. Is there any other pcms I can use and / or is this even the correct one.
Must get one from the same yr/model to ensure you'll run properly. If the engine is swapped and it is not the same as the previous that came with the car it needs to be stated.
Same motor and pcm that was in car when I bought it....so the issue is I have a crank no start...brand new distributor main relay and even changed out the pcm last night. I checked all fuses and all checked out. Checked the ignition system as well and that checked out too. Idk where else to go
