Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Fuel Cut
Old Jan 10, 2021 | 04:59 PM
1OutThere's Avatar
Default Fuel Cut
My civic has a bit of a "lurch" when the fuel cut activates and deactivates. It's more pronounced in the lower gears like one would expect, but I would really like to find out how to smooth this out if it's possible. It's had this little glitch since I've owned it.
What's been done so far:
Cleaned throttle body (gently).
Cleaned IAC valve.
Set TPS to .45v @ closed throttle.
Performed idle re-learn.
Checked for vacuum leaks (none found).
Replaced PCV valve (with Autozone part, factory Honda valve on the way).
Checked/adjusted valves
Replaced spark plugs (factory Denso) & air filter.
Any ideas are welcome; thanks!
preludequestion
Oct 19, 2009 11:41 AM
ludedude1975
Dec 10, 2008 12:16 PM
awp1965
Oct 4, 2008 07:33 PM
KRiS1
Apr 22, 2002 07:05 AM
