RSX base or Type S K24A2
Old Jan 10, 2021 | 10:22 AM
dirtdiggler666's Avatar
Default RSX base or Type S K24A2
Ok guys I have been out of Hondas for a very long time so any info would be good.
I am looking into building a RSX and am building K24A2 and was wondering if the swap is easier in a type s or to use just a base model RSX? And if anyone has links to what needs to be done and or changed that would be great?
Old Jan 10, 2021 | 09:29 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: RSX base or Type S K24A2
The K24 in the Type S is the better call... but then again, as you can see from my sig, I am a bit biased. Other than the CRV engine bracket, everything else works pretty well. Header fitment may be an issue depending on what you have... if you get a RSX header designed for the K24, you should be just fine.
wangani mandala
Nov 14, 2017 02:12 PM
Integra4Life89
35
May 16, 2004 12:27 PM
NiiS
Jun 19, 2002 08:47 AM
