I996 Honda Civic LX
Old Jan 10, 2021 | 01:09 AM
ZayFuller's Avatar
Default I996 Honda Civic LX
I have a 96 Honda Civic lx sedan and I want to do a B20 Swap, but I don’t know everything I would need any help?
Old Jan 10, 2021 | 10:48 AM
Feriohhh's Avatar
5 Year Member
Default Re: I996 Honda Civic LX
Roughly what you'll need to get a basic swap up and running:
  • B20 (CRV) Engine (newer the better)
  • B18B (LS) Intake manifold (or aftermarket for a B18A/B) with 96+ Integra RS, LS, GS throttle body, sensors, injectors
  • 94+ Integra RS, LS, GS, GS-R, Type R or 99-2000 Civic Si transmission, clutch, flywheel, throw out bearing, pilot bearing
  • Mount kit for 96-2000 Civic with B-series swap or 99-2000 Civic Si mounts
  • Buy a wiring kit or modify your existing engine harness to fit the layout of the LS engine
  • 96+ Integra RS, LS, GS OBD2a ECU (P75)
  • Shift linkage from 94+ Integra RS, LS, GS, GS-R, Type R, 99-2000 Civic Si or 94+ Del Sol VTEC
  • Axels from 94+ Integra RS, LS, GS, GS-R, Type R, 99-2000 Civic Si or 94+ Del Sol VTEC
If you actually make it that far, check deeper in the forums. There are many, many threads on this and the non-vtec B20/B18 swap is about as easy as it gets.
jdmson43
Jan 1, 2012 08:46 PM
seeeya04
Jan 29, 2005 10:05 AM
Osiris94EJ
Jul 17, 2004 09:20 AM
MickeeFREE
Mar 4, 2003 10:28 PM
