Cluster swap issue 6th gen hatchback
Old Jan 9, 2021 | 11:37 AM
bmore206's Avatar
Default Cluster swap issue 6th gen hatchback
my 97 hatch had the cluster with no tach, worked fine but being a manual i wanted a tach, so i purchased a cluster from a 98 coupe that has a tach. Looked online everywhere stating that they are all plug and play, which it seems as tho it is. All plugs match up in the rear, two green/teal colored plugs upper and one smaller yellow one to the bottom.
my probelm is when the car is on the tach works but the fuel and temp guages do not.
i followed all the “wires” on the sheet and they seem to be in the correct places.
any ideas? Please and thank you.
Old Jan 9, 2021 | 09:06 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Cluster swap issue 6th gen hatchback
Maybe those two gauges are actually broken in the cluster that you bought.
Old Jan 11, 2021 | 06:51 PM
NVturbo's Avatar
O.G. triple O.G.
all 96-00 Civic clusters are interchangeable, including the SI coupes. You can also swap in ones from a CRV (96-01). If the side gauges don't work, that cluster is messed up
andre3wap
Dec 6, 2013 01:29 PM
V.MoMO
Sep 12, 2010 08:44 AM
triple5soul8781
Aug 7, 2008 05:46 AM
FifthGearOnline
Mar 28, 2002 05:09 AM
CivilizedCiv
Mar 18, 2002 03:59 AM
