Honda Odyssey ECU Swop
Hi guys
I am in need of help please. I have a 98 Odyssey based in South Africa.
Vin is JHMR3880WC203247
Engine No F23A81000704
ECU No 37820- PEA - N50
I need to know a possible replacement no if possible or the ecu decoded into which alternative can work in its place. I had a manual ecu and fitted it so car starts but no gear shift.
Is there anyone that can help me in the right direction pease.
The ecu i want to buy is 37820 PEA 900 can this work? Emissions is not a problem in my country. Well they not as strict.
I have hit a brick wall trying to find alternatives. Please help and thanks in advance.
Yes that should work. Not 100% on whether or not the JDM ECU's or your Odyssey have an immobilizer installed though. If it does then you will have to get the ECU immobilizer programmed if they don't you are good to go.
