Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
K20z3 bottom end - k24a top end
Old Dec 31, 2020 | 07:05 PM
Alexdachamp's Avatar
Default K20z3 bottom end - k24a top end
Picking up a k24a tomorrow , looking for builds to make around 400 ish hp probably going turbo , any help or tips would be appreciated, what I should look out for or even your own builds would help than nmd !
I have a 09 civic si coupe if that also helps
Old Feb 7, 2021 | 05:31 AM
Vinnysfb6's Avatar
Default Re: K20z3 bottom end - k24a top end
usually for frank motor builds for k series its better to do the k24 bottom for torque and the k20 head for top end power. I personally have never seen anyone do k20 bottom with a k24 head
Old Feb 7, 2021 | 08:19 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
This is a very generalized statement and doesn't fit every requirement... and a fine one found on the Internet. In the real world, it is more complicated than this.
A turbo kit will make 400 WHP with either engine... no head change is necessary. Your post title suggests an uncommon combination... especially if the K24A that you have is not a TSX engine or equivalent JDM version. The cylinder head from an Accord, Element or CRV would be a step backwards in a street car, so I wouldn't suggest that combination.
ĖLLĖCĖTep3
K Series
Mar 3, 2016 01:13 PM
LovelyEK
May 21, 2010 10:46 PM
Frost7177
Feb 14, 2009 07:38 PM
roycivic92
Jan 10, 2005 08:12 PM
