Chipped ecu in a 2000 honda accord
Put the original ECU back into the car... a chipped ECU will not communicate to the automatic transmission control box, and this is why you cannot shift the transmission out of "Park".
[QUOTE=JRCivic1;52332205]Put the original ECU back into the car... a chipped ECU will not communicate to the automatic transmission control box, and this is why you cannot shift the transmission out of park
Can I hook up a v tec controller or reprogram my computer what would be the best way to tune my car
[QUOTE=Ne Bg;52332234]
Look into this. https://honda-tech.com/forums/perfor...ports-3233058/
It states you need to run a separate TCU to run a modified ECU.
[QUOTE=EWY;52332767]
That is an option... but I don't think this is what the OP has, and thus, WHY the transmission doesn't shift.
Basically, what you linked WILL work... what the OP has WILL NOT work.
No doubt about it... and your suggestion for a solution is "Fantastic". I was merely trying to differentiate what you suggested from what the OP "has" so that he/she understands WHY the transmission cannot be shifted out of park.
hondanoob1
Aug 17, 2018 06:57 AM
smokin rubber
Dec 21, 2002 11:54 AM
