Help ASAP b20 swap running on 1 cylinder
Old Dec 22, 2020 | 07:38 PM
Turbodelsloww's Avatar
Default Help ASAP b20 swap running on 1 cylinder
Hey guys I had a b18b1 turbo del sol was tune with Hondata the motor blew a rod so I thru in a b20b now it’s misfiring my question is would the tuned of the b18b1 turbo effect the the way the b20b runs ? Would I have to get it retuned
Old Dec 29, 2020 | 12:35 PM
Sic_DA_Nine's Avatar
Default Re: Help ASAP b20 swap running on 1 cylinder
Originally Posted by Turbodelsloww
Hey guys I had a b18b1 turbo del sol was tune with Hondata the motor blew a rod so I thru in a b20b now it’s misfiring my question is would the tuned of the b18b1 turbo effect the the way the b20b runs ? you should be able to start and drive with the b18 map, would it cause a misfire? probably not. Would I have to get it retuned depends on what you consider "have to". should you? yes, have to? no
Check your timing, see which cylinder is missing.
you would not be able to start the car if you are running on 1 cyl.
