Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2003 acco jerking after pushing the gas pedal.
Old Dec 21, 2020 | 02:53 AM
EURO1215 Medex's Avatar
Default 2003 acco jerking after pushing the gas pedal.
This might be repeated but I've seen soo many threads with soo many possible outcomes. Althought there wasn't much of a info too.
Soo my problem is: car runs perfectly fine. In neutral. No problem how ever I push the gas pedal. When iam in a gear tho and I let the gas pedal off. And then try pushing it again. That's where it jerks like once. Like it kicks or comes to 20% gas already. No matter how gently i press the gas pedal. It's barely noticeable at 1500rpms. Higher is worse. It also does it with tempomat. Once i go Down a hill And the throttle goes off and then on - jerk.
Thank you for any ideas!
Old Dec 23, 2020 | 11:59 AM
lpaz's Avatar
Default Re: 2003 acco jerking after pushing the gas pedal.
are there any engine codes?
maybe the TPS..?
Old Dec 23, 2020 | 02:06 PM
maybe the TPS..?
Noope nothing at all. It's hardly noticeable. It did the same thing in my civic. Maybe it's just the common wear of the car.... But I wonder if there's something that can be done to fix it
