Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Immobilization system
Old Dec 19, 2020 | 05:28 PM
1973Motion's Avatar
Default Immobilization system
I have a 2010 Accord I purchased in 2013. I have changed the battery twice with no problems. I changed the battery this September and a problem has happened. Right after installation of the battery, I attempted to start the car. It ran for maybe one second and shut off. The key was in the on position, so I tried again. Two things happened. The check engine light came on and the image of the key began to flash. I took the key out of the ignition, waited for the flashing of the image of the key to stop, inserted the key again and attempted to start. It did, but the check engine light stayed on. I contacted a friend in another state who is a service tech for a Honda dealer. He told me its the immobilization system. He worked with me trying to get the problem to stop but to no avail. For example, he told me to disconnect the negative cable, leave it off for 10 minutes. Reconnect and wait for 10 more minutes then start the car. It worked! Unfortunately the next time I attempted to start the car, the problem returned. If I stop and shut the car off, maybe for 5 minutes, the car will immediately start but the check engine light does stay on. He's had me try other possibilities to resolve the problem but obviously no luck. I even went to 2 Honda dealers and no help. I'm opening to any/all suggestions.
Old Dec 22, 2020 | 11:21 AM
Eugene1979's Avatar
Default Re: Immobilization system
What was the CEL code? if the car starts but with CEL then it's not the immobilizer. R u sure you didn't disconnect a vacuum hose somewhere when pulling the batterY?
Old Dec 22, 2020 | 11:37 AM
1973Motion's Avatar
Thanks for the response. Don't have a clue about a CEL code. Need 1000 H/P out of a BBC? That I can do. I'll have to check for a vacuum leak but I'm pretty sure that didn't occur. When I left the last Honda dealer, the CEL wasn't on. A couple hours later, I started (attempted to) the car and the same old thing happened. Attempted to start, ran for a second and shut off. Tried again, no luck but the key indicator came on and the CEL was on. Pulled the key, waited for the flashing key to stop, put it back in and turned it over and it started right up. CEL stayed on. My friend told me the flashing key is directly associated with the immobilization system. The car has 237K on it and it runs so well. I always had the maintenance performed. Plugs, filters, etc. I would take care of. The dealership would do everything else.
Old Dec 22, 2020 | 12:06 PM
Eugene1979's Avatar
Then you're guessing. Get the code read and address the real issue. don't guess
immobilizer won't let you start the engine, it'll just crank forever
Old Dec 23, 2020 | 11:56 AM
lpaz's Avatar
was there a solution for this issue?
Old Dec 23, 2020 | 12:23 PM
1973Motion's Avatar
As stated, I had it to 2 dealers. They explained to me when the engine starts and shuts off immediately, the fuel injection system is killed due to the immobilization system being activated. By waiting for the key to stop flashing on the dash means the immobilization system is now shut down and the car will start which it does. Unfortunately, they couldn't find the cause. I understand how the chip in the key FOB could be causing this. I asked them to check it but I don't know if they did or not. Anyway to check the chip to see if it corresponds with the program?
Old Dec 23, 2020 | 01:50 PM
Eugene1979's Avatar
As i said, immobilizer won't let you start the car at all. If it starts, then it's not the key. get codes read and go from there. You're guessing and it won't help.
Old Dec 23, 2020 | 03:23 PM
1973Motion's Avatar
And as I said, the immobilizer shuts down when the flashing stops. The dealer told me that. Guess they're wrong also.
Old Jan 1, 2021 | 06:16 PM
Eugene1979's Avatar
Did you get it figured out?
jackloconnor
Honda Civic (2001 - 2005)
May 19, 2015 05:19 PM
nix94delsol
Jan 22, 2008 05:38 PM
ANONYMOUSdeecee
Mar 7, 2007 07:47 PM
