CRV.III.2007.DualZone.Utasoldalon mindig csak hideget fuj
hello
Heating problem: DTC B1233 (driver aix controll motor failer circit) ,, Heating works correctly on driver's side , but always cold on passenger's side!!! Driver's air mix control motor has been replaced with a good motor.,. nothing.. the same situation!!!
Continuity Checked between driver air mix controll motor and Klimapanel (40 PIN) OK., Heating cable and air door in box move easily.
Not sure., if there should be a mixer motor on the passenger side as well ??? If so, where is it located? It would be very important to know this !!! I see a Mode control motor. , and a Recirculation motor anyway !! These motors work well on the other hand.
thank you for all your help
