1998 Accord V6 alternator/battery L shaped crimp lug on main fuse block
Old Dec 18, 2020 | 07:54 PM
rchapman's Avatar
Default 1998 Accord V6 alternator/battery L shaped crimp lug on main fuse block
I need to find a couple of these L shaped crimp lugs for the big 3 upgrade I am installing. Where can I get them ? I have searched the net and only come up with compression lugs...they are similar but not what I need. I am also thinking about just running the new 1/0g wire straight to the battery from the alternator and bypassing the fuse block and add an inline ANL fuse block between the two. Then run a 4g wire from the battery to the alternator connection point to power the fuse block and car. That should work right ? It should still power the fuse block and still utilize the factory 110A main fuse. Thanks.
Old Dec 19, 2020 | 02:24 PM
99stockcivic's Avatar
Default Re: 1998 Accord V6 alternator/battery L shaped crimp lug on main fuse block
I would think someone like crutchfield has those:
https://www.crutchfield.com/fg_34885...-Hardware.html
Old Dec 21, 2020 | 06:42 PM
rchapman's Avatar
No one has it. I cannot find it on the Honda Parts site either. It's a f'n mystery...lol.
