Fuel pump cut off switch
Hi im makeing one of my cut off switches at the fuel pump and was woundering if I need to run a relay so my switch dont burn up. I know there's alot of info online but also read people haveing problems with switches burning up so was just woundering how I can fix this
use the ground wire at the PGMFI relay and you won't have to worry about burning anything up
People burn up the switch because they ARE INCOMPETENT, not due to a faulty switch.
