Can I tune my OBD0 injectors on a OBD1 p28 ECU?
Old Dec 16, 2020 | 08:10 PM
jonathanmasta's Avatar
Default Can I tune my OBD0 injectors on a OBD1 p28 ECU?
Hi, I have a 1987 CRX, EW3/D15 inejcted engine
The old injectors went bad I put 88 Prelude injectors on and it works(but it has a higher flow rating)
I want to convert the ECU to OBD1 to tune it with CROME, I know the parts that I need to convert it(Adapters,Distributor), I also got the tuning equipment,)
Is that enough to be able to tune the injectors? Or do I have to buy OBD1 injectors?
(I prefer using those OBD0 ones that i put in)
Thank you!
Old Dec 17, 2020 | 08:26 AM
7rrivera7's Avatar
Default Re: Can I tune my OBD0 injectors on a OBD1 p28 ECU?
You can use the OBD0 (LOW) injectors which are peak and hold @ ~5 ohms as long as you have a resistor box inline. The OBD1 ECU is looking for injectors in the range of 12-15 ohms (HIGH).
Old Dec 17, 2020 | 09:50 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
^^^^^^^^^^^^^^^ This.
