Transmission & Drivetrain Gearboxes, Differentials, Clutches
K24 accord trans in rsx k20a2
Old Dec 16, 2020 | 06:40 AM
Billyb54's Avatar
Default K24 accord trans in rsx k20a2
I raise circle track and I need a different gear ratio does anyone know if A K24a2 transmission in rsx what all needs to be changed? Axles?
Old Dec 16, 2020 | 05:03 PM
Ryanthegreat1's Avatar
Default Re: K24 accord trans in rsx k20a2
Pilot bushing in the flywheel, K24 stuff is larger diameter. The rest should be the same. Transmission mounts may or may not bolt up. Can always put the guts of the K24 into the K20 case.
