Hydraulic Throwout Bearing, Clutchmaster
The unit has two lines that run out of it. Where do you hook each line up to? Do you need a new master cylinder and if yes, which one? Thanks.
One line comes from the clutch master cylinder. The other simply is an extension to outside of the transmission case so that you can BLEED the system. My Tilton assembly came with the bleeder fitting on a short piece of braided hose.
