Oil leak on front of D15A3. Where's it coming from?
Old Dec 15, 2020 | 01:30 PM
RedBolide's Avatar
Default Oil leak on front of D15A3. Where's it coming from?
I'm tackling as much as I can on my first Honda, and I'm trying to track down an oil leak. It's an '87 CRX with a D15A3. I thought it was the valve cover since the whole engine/trans was caked in sludge. I cleaned it up, drove it, and my leak isn't the valve cover. I took some pictures.
By the looks of it, the leak is on the psgr side of the front of the block. It's a pretty heavy leak; in 30 miles I lost about half a quart. Does anyone have any insight on what this leak might be caused by? I'd just rather confirm before I start buying parts. Thanks!
Old Dec 15, 2020 | 01:32 PM
RedBolide's Avatar
Default Re: Oil leak on front of D15A3. Where's it coming from?
Old Dec 15, 2020 | 04:08 PM
DaX's Avatar
DaX
Loved
Community Favorite
Check the distributor o-ring (if it has one), or the shaft seal inside the distributor.
Old Dec 18, 2020 | 06:15 AM
RedBolide's Avatar
Well, looks like you're dead right. The o ring inside was flattened and brittle. Definitely the source of my leak. Sadly, it looks like Honda discontinued the part so I tried a GM 2.5in o-ring. It's definitely a hair too big, but I'm hoping it'll be enough to seal. Gonna check it this afternoon. Thanks for the help!
Old Dec 22, 2020 | 05:58 AM
RedBolide's Avatar
Yep, problem solved! Distributor o-ring had gone bad. The GM o-ring didn't fit (too big, and caused a worse leak than before), so I ended up using a lot of RTV to seal it. I'm going to keep searching for the proper o-ring, but it is surprisingly tough to track down. For now, thank you. I'm not losing all of my oil now!
Old Dec 22, 2020 | 03:58 PM
DaX's Avatar
DaX
Loved
Community Favorite
Glad you got it sealed up. You may be able to go to an auto parts store and ask if you can rummage through their o-rings. I've done that before and found what I needed.
