Chipped p28, not priming, constant CEL
Does anyone ever encountered this problem:
I turn the key on, the engine cranks but the fuel pump won't prime, and I have a constant CEL.
It's a 1999 civic sedan. I have a chipped p28 with AEM uego wired to the conversion harness, and the gauge won't get power (won't turn on), and I can't datalog with HTS, just like when you plug the datalogging port but won't turn the key.
The thing is that I was testing another p28 ecu with a fried q31 transistor, and right after that I got the problem described above.
I tried my ecu and another chipped p28 and it won't change anything. I have tried replacing the main relay, and all other relays, I have checked all fuses, and still got nothing.
I don't know if it's a coincidence or not, but it looks like it's not an ecu related problem.
