00 Si & 96 EX-R trans seals questions
Old Dec 10, 2020 | 12:57 PM
ERA_Evil's Avatar
Default 00 Si & 96 EX-R trans seals questions
So Si is mine, 96 is wifes.
Hers is an automatic and trans is failing so gonna get a manual swap. I want to get a few things done and new parts in. Usually swaps are done with the donor car parts but i want to put in new. D16Y8
​​​​​​So new clutch, pressure plate and flywheel
rear main seal
New clutch master, slave and line (braided)
Axle seals and shift rod seal (correct me if im wrong on below parts numbers)
91205-PL3-A01
91206-PL3-A01
91215-PL3-005
What else is there to do while im at it??? I feel like im missing something. Additionaly I have not yet confirmed the exact tranny going in. Any suggestions for a specific make/model? She aint gonna be racing but definitely spirited driving and occasional highway use so overdrive is a pretty much a must
For the Si, i want to change the oil seals, S4C trans apparently no LSD as it does not have the marking nor have i opened it up. Does not feel like LSD turning
91205-PC9-711
91215-689-013
91205-PL3-A01
Axle and shift rod seals. Am I missing any other seal? And are these the correct part numebers for an Si?
Old Dec 27, 2020 | 07:45 PM
ERA_Evil's Avatar
Default Re: 00 Si & 96 EX-R trans seals questions
So no one in HT knows?
Old Dec 28, 2020 | 04:28 AM
tony_2018's Avatar
Fish Twig
I would defer to the online parts dealer diagram. Pretty spot on.
Old Dec 28, 2020 | 06:45 AM
ERA_Evil's Avatar
Yup, thank you very much, part numbers were taken from hondapartsnow.com diagrams. Was looking to see if anyone has any ideas on any other things to do while i am at it. Any other seals i may be missing or preventative maintenance. Since trany is going off, for example, might as well change rear main seal and axle seals
Old Dec 28, 2020 | 06:48 AM
tony_2018's Avatar
Fish Twig
They're usually never wrong but punch in your VIN
Old Dec 28, 2020 | 06:54 AM
ERA_Evil's Avatar
On the Si its no problem, that S4C trans is pretty much unique.
The issue is on my wifes car, since it is an automatic, being converted to manual, i am not entirely sure from what donor car its gonna come from, and i would love to have all the parts before starting the swap. Which is why I was also asking for ideas on the donor car trans, and what to change oit while its being swapped
