Suspension & Brakes Theory, alignment, spring rates....
HELP rsx suspension interchangeability
Old Dec 8, 2020 | 06:00 AM
Billyb54's Avatar
Default HELP rsx suspension interchangeability
OK guys I have a weird long winded question.
Also yes I have done my research but what I'm looking for is a little bit different lol.
I run circle track and I have an 04 RSX I was wondering what Springs and struts inner change I'm really looking more towards accords elements or crv As I need stiffer springs in certain spots also taller springs and struts.I have read that Gen2 crv struts will Bolt on But I was also wondering about accords or elements anything a little bit heavier. Thank you guys in advance for all of your info
Old Dec 8, 2020 | 05:02 PM
Ryanthegreat1's Avatar
Default Re: HELP rsx suspension interchangeability
The Accord, CR-V, and Element, Odyssey are all similar struts in the front. Element is going to be the longest strut with the heaviest spring.
Old Dec 8, 2020 | 05:04 PM
Billyb54's Avatar
Ok awesome I will try one tomorrow and see what changes it makes on the scales
Old Dec 8, 2020 | 05:28 PM
And the Element has a larger taper for the rod end link. Easy enough to swap rod ends if you end up using the body of the strut from an Element.
Oh also I think the 02 and early 03 RSX had smaller strut pinch bolts. The later 03's and up had the larger diameter pinch bolts. M14 vs M16 bolts.
Old Dec 9, 2020 | 03:40 AM
Billyb54's Avatar
Ok awesome thank you do you know about accord spring rate? I'm trying to get options so I can make more adjustments
