clutch cable and linkage adjustment on 88 accord??
Old Nov 16, 2002 | 11:12 AM
BIGBLOCKEK's Avatar
Botched thread poll
Default clutch cable and linkage adjustment on 88 accord??
can somebody please give me a few tips about performing these simple maintence procedures. im a honda newbie trying to help out a sweet girl. thanks
Old Nov 17, 2002 | 08:01 AM
89_LXi's Avatar
Default Re: clutch cable and linkage adjustment on 88 accord?? (510crx)
Clutch cable is pretty easy to adjust. If you follow the cable down to the tranny, just before where the cable attaches to the realease arm, there is a large (about 1 inch) plastic nut. If I remember correctly, clockwise tightens the cable and counterclockwise loosens it. If it hasn't been adjusted for a loooong time and there's currently no pedal freeplay, you may need to put a jack under the release arm and raise it up just a couple inches to release the pressure from the cable, then loosen the nut. Take the jack out and adjust the nut until there is about 1 inch of freeplay in the pedal. The nut sets down inside a rubber grommet thingy that keeps it from turning, so press the pedal down a few times to get it set in there before measuring the freeplay. If it's off, just repeat the above until it's where you want it. It takes quite a bit of fiddling to get it just right, but it's not hard at all.
b16_swap
Jul 23, 2008 10:07 AM
pauley01
Jan 22, 2007 10:43 AM
EKIM NART
Mar 12, 2006 06:06 PM
Verdegsr
Nov 9, 2003 07:11 AM
Sirex
Sep 26, 2003 07:55 AM
