99 ek coupe signal not working
Old Dec 6, 2020 | 04:14 PM
Jhumel Tibule's Avatar
Default 99 ek coupe signal not working
Hello everyone,
I've been searching for answers, and haven't come up with anything.
Turn signals aren't working. 7.5amp fuse is fine. Bulbs are fine. Could it be the lever? Or the flasher relay?
Old Dec 6, 2020 | 07:03 PM
muellersfan's Avatar
Default Re: 99 ek coupe signal not working
Do the hazard lights work?
Old Dec 6, 2020 | 07:06 PM
I dont have a center climate/radio so not even a button to use the hazards..
Old Dec 6, 2020 | 07:13 PM
This^ is the problem.
Old Dec 6, 2020 | 07:19 PM
I'm sorry if this sounds dumb.. but I didnt realize I needed the whole center climate/radio to use my signals? Never seemed like a problem to some other friends without it
Old Dec 6, 2020 | 07:38 PM
You need the hazard switch because it is also part of the turn signal circuit.
Old Dec 6, 2020 | 07:42 PM
ohhhh i see i see.
I wont be able to get a climate/radio until a bit. This is probably really janky, but is there a way to wire and use the hazards without the center?
Old Dec 6, 2020 | 08:05 PM
Can you find the connector for the hazard switch?
Old Dec 6, 2020 | 08:23 PM
ill try to look for it tomorrow after work.
is it color coded? There's just a whole mess of wiring in the center where the climate and radio goes. I know that I am missing some connectors so im hoping that its still there.
Old Dec 7, 2020 | 04:56 AM
The 10-pin hazard switch connector (C513) is gray. Use the C513 wire colors shown in the circuit diagram for identification.
When you find C513, use a wire to jump pin 5 to pin 10 in the connector. This should make the turn signals function.
