H23 having trouble starting after headgasket replacement
Old Dec 6, 2020 | 12:47 PM
Not Billy's Avatar
Default H23 having trouble starting after headgasket replacement
Last week i replaced the head gasket on my prelude and now it's having trouble starting. when i press the gas it bogs down and dies while cold, it runs alright when up to temp. one thing It might be is the vacuum lines, my phone broke and i lost the pictures of them before i tore the engine apart, also it's been sitting for about a year so it might just be bad gas, Honestly don't know that's why i'm asking, any insight is appreciated.
(sorry about the wind noise, i was doing body work while the battery was charging and forgot to take off the respirator)
Old Dec 6, 2020 | 01:07 PM
Aradin's Avatar
Premium Member
Default Re: H23 having trouble starting after headgasket replacement
Did you set the ignition timing correctly after doing all the work?
Old Dec 6, 2020 | 01:34 PM
Not Billy's Avatar
I believe so, it's supposed to be set to 15 degrees right?
Old Dec 6, 2020 | 04:25 PM
Aradin's Avatar
Premium Member
Generally yes, some wiggle room there. Any signs there are issues with the repair? Fouled plugs, smoke, etc. Any stored codes? If neither, bad gas would be an easy thing to rule out. Just let it idle until it's half tank or less, fill it up with premium and see if there's improvement. Maybe throw some fuel system cleaner in it.
Old Dec 6, 2020 | 11:23 PM
Not Billy's Avatar
There was a fair bit of smoke but i adjusted the valves and now that's not an issue, i'll throw some good gas in it and see if that's it.
Old Dec 9, 2020 | 11:16 AM
minilogoguy18's Avatar
Simple, timing belt is out of time by a tooth or 2.
