Transmission & Drivetrain Gearboxes, Differentials, Clutches
98 civic with B18c - DUAL FRICTION CLUTCH
Old Dec 5, 2020 | 09:53 PM
187Chor's Avatar
Default 98 civic with B18c - DUAL FRICTION CLUTCH
I'm about to do a turbo set up on my B18C and am purchasing a clutch/flywheel combo.
I have had a 6 puck clutch in the past and did not like the aggressive engagement.
I am told a dual friction clutch is the way to go, as it is a very smooth engagement.
My question is, how much power would it hold? I understand there are different stages, but hypothetically, what's the max power I can expect it to hold from a kit not not breaking the bank?
I am shooting for 350hp to the wheels
Old Dec 5, 2020 | 10:36 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: 98 civic with B18c - DUAL FRICTION CLUTCH
Clutches are rated on maximum torque values.
Find out how much torque you're shooting for and then pick an appropriately rated clutch to handle the torque. Obviously going higher than what you are shooting for, in case you make more power than you thought or decide to turn up the boost.
Old Dec 6, 2020 | 11:49 PM
187Chor's Avatar
Thanks I knew that. I was asking specifically about dual friction clutches
Old Dec 7, 2020 | 12:29 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Dual friction is just a term used by Centerforce... and it basically describes using two different materials on the clutch disc face instead of one like most clutch manufacturers do. This doesn't alter the engagement... that is typically more related to the disc type (sprung hub or solid hub) combined with the rate/weight of the pressure plate.
