D16Y8 build questions
Old Dec 4, 2020 | 05:01 AM
Cannabutter's Avatar
Default D16Y8 build questions
Hello, I have a 98 civic ex manual swapped.
I got ahold of another D16Y8 to build while I daily my current motor and I noticed that the motor I picked up doesn't have a crank position sensor like the obd2 motor currently in the car. Does that mean it's a different one? Or what do I need to do to get it to work in my car? Or would it be best to build in the obd2 engine that's in the car currently.
Old Dec 4, 2020 | 05:43 AM
muellersfan's Avatar
Default Re: D16Y8 build questions
Post pictures of replacement engine.
Transfer the CKF sensor from current engine to replacement.
Old Dec 4, 2020 | 05:45 AM
Will there be a spot for it on the replacement to just plug and play? And I'll upload some pics later today.
Old Dec 4, 2020 | 05:56 AM
Remove crank pulley and lower timing belt cover, and then post pics of crank gear area.
What are the engine block and head codes? Post pics of those as well.
Old Dec 4, 2020 | 03:49 PM
NVturbo's Avatar
O.G. triple O.G.
there should be a threaded hole close to the crank pulley (upper right) to mount the CPS. The threaded hole is a part of the oil pump.
