93 Del Sol si ride height
Old Dec 2, 2020 | 01:40 PM
Rango_the_Sol's Avatar
Default 93 Del Sol si ride height
With my new project I am eager to get some suspension work started.
While installing my LS meshies I found that the springs on the car are green Tiens but the shocks look stock. My problem is that I can't see any other identifying numbers on the springs to know how much this car is lowered. I would like to have an idea of where the car would sit after I put on a fresh set of coilovers with a moderate drop, but since I am not sure what my currrent baseline is, I might not get a drop at all.
Does anyone have an idea on the best practice for figuring this out? I saw a couple conflicting answers for stock ride height elsewhere so I wasn't confident I was getting a correct answer. I felt this was a semi specific enough question to put here rather than the suspension forum.
This is currently how the car sits.
Old Dec 3, 2020 | 11:02 PM
Default Re: 93 Del Sol si ride height
Anyone?
Old Dec 5, 2020 | 10:22 PM
Not a peep.. alright then
Old Dec 6, 2020 | 07:03 AM
94 Civic Si's Avatar
Premium Member
Loved
Community Favorite
So you think you have lowering springs on factory shocks?
That sounds a little less than ideal.
Question, if you lift from the front or rear, do the springs run out of reach/travel before the shocks do?
Old Dec 6, 2020 | 09:28 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Did it occur to you to get numbers off the springs and contact TEIN to discover what you have ? Your car doesn't appear lowered at all... so there is likely more to this issue than you think.
Old Dec 6, 2020 | 09:57 PM
Good attempt at being a duck when I said in my post I couldn’t read any numbers on the springs. I can only see the tien logo.
so far when I have put the car on stands I haven’t noticed that the springs come off the perches of the struts but they do droop down quite a bit. All the suspension is worn but I plan on changing all that out.
I am not sure if it is lowered at all, I’m kind of hoping it isn’t so I can clear a little wheel gap with the fresh coil overs
