Honda Passport 2019 Touring TPMS Reset
Hello,
I got low tire pressure last night on the right tires front and back. After adding air to the two tires, and going to setting ->Vehicle-> there was no TPMS option found.
Any steps I am missing against the Honda manual and YouTube videos? I was able to verify the air added into the two tires which showed 32PSI in each.
Thanks
Thanks
After returning from the holidays I got it taken care of. The sensor would not go away so I drove it to discount tire. The person said the new Honda's are strange unless you are using a industrial air pump. I was sitting in my car, and the person at discount said it will go off instantly once we use our machine. As stated it went off instant.
I had them put air in all four tires even though only the right side needed it.
Cannot complain it saved me a trip to the dealer. Annoying as I have used my home air pump with my Highlander, and Sonata (which I replaced for the Passport) and never had any issues with getting the TMPS to go off in either car.
Cheers!
Cheers!
Last edited by desiguy2447; Dec 29, 2020 at 09:01 AM. Reason: wrong model listed instead of Passport put Pilot
