Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Can I swap a 02 ecu into a 04 civic for a mini me swap?
Old Nov 24, 2020 | 09:15 PM
Bsriptide01's Avatar
Default Can I swap a 02 ecu into a 04 civic for a mini me swap?
Hey guys I looked thru and couldn’t find anything like this idk maybe I missed it but I’m planning to do a mini me swap, a d17a2 head onto a d17a1 block and I’m going to look for the parts tomorrow I was trying to figure out can I use a 2002 civic ex ecu on a 2004 civic? Ik the o2 sensors are different but would it affect anything if I used the 2002 civics 02 sensors to account for that since it will be a 2002 ecu head and wire harness? Thanks for the help guys!
Old Nov 25, 2020 | 03:55 PM
sumdewd's Avatar
Default Re: Can I swap a 02 ecu into a 04 civic for a mini me swap?
Assuming you're using the full D17A2 EX harness, if you change the computer you will have to bring it to a dealer to have the immobilizer/keys reprogrammed/matched. Do you have access to all of the matching ignition switch/key components from the 2002?
