02 Si occasionally won’t start after a drive?
After a 30+ minute drive, and I shut the engine off, it refuses to start again unless I wait over an hour or so. The engine does not crank at all, and the battery appears to be fine, however jumping the vehicle will fix the issue immediately. when i turn the key, i can hear the fuel pump working, and also two clicks. the car always starts the first time i turn the key on a new day, it’s just for a period after a long drive. i’ve read on here that this issue might be the main fuel pump relay or the distributor, and i’m curious does jumping the vehicle bypass those problems if they were indeed bad? i’d appreciate any input/feedback!
