B16A2 starter on GSR
Old Nov 21, 2020 | 02:22 PM
Jdpt2's Avatar
5 Year Member
Default B16A2 starter on GSR
I'm in the process of swapping a GSR engine in my EM1. I'll like to know if the starter from my EM1 will work with the GSR. I've also purchased an Exedy lightweight flywheel and stage 1 clutch.
I've read posts stating that all manual starters are interchangeable, but none specifically using an EM1 starter with a GSR. I question its compatibility as part numbers for the starter are different. And wonder if the aftermarket flywheel will make a difference as well. Thanks for your help.
Old Nov 21, 2020 | 08:21 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: B16A2 starter on GSR
The starter will work just fine on a GSR. The flywheel should work just fine as well.
