Gauges Die Under Full Throttle
So recently when I've been driving spiritedly (pedal at WOT) soon as I hit boost, around 3500 RPMs the tach just falls flat on it's face and becomes unresponsive! The speedo is fine, and my blinking CEL shift light still works. Any idea what would cause this? I tried reseating the cluster wires.. I tried reseating the distributor wires and I checked ALL the grounds.
Ive heard of failing ignition coils giving bad tach readings.
When this happened to me the tach would cut out intermittently, ended up being a broken wire at the dizzy that didn't look broken to the naked eye.
