Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Tail lights, parking lights don't work
Old Nov 14, 2020 | 12:19 PM
Mike6677's Avatar
Default Tail lights, parking lights don't work
The tail lights and parking lights stop working, all othe lights work, small lights fuse and bulbs are ok any clues?
04 accord 4cly auto
Old Nov 15, 2020 | 11:39 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Tail lights, parking lights don't work
1. Check/Re-Check under-hood Fuse No. 4 (15A).
2. If fuse is okay, disconnect Connector A on the Combination Light Switch. Jump harness connector terminal no. 3 (Blk wire) to terminal no. 1 (wht wire). If the tail lights and parking lights work, the cause may be due to a faulty combination light switch.
3. If the lights still don't work, the cause may be with the tail light relay which is part of the relay control module (built into the under-hood fuse/relay box) or wiring after the under-hood fuse/relay box. You'll want to test for power on the Red/Blk wire (red colored wire with black stripe); terminal no. 3 at Connector D at the back of the under-dash fuse box is where you can test for power at the Red/Blk wire.
