Pictures on how to fix your loose window...
Old Nov 16, 2002 | 09:25 AM
Pineapple Devil's Avatar
Default Pictures on how to fix your loose window...
Mine came loose again so I took pictures this time on how to fis it. As you see in the pictures, there is a rubber weather stripping that is inline with the window. That is the piece that comes off that makes the window rattle. Usually you can find it in the bottom of the door if it fell off. To put it back on, roll the window down about an inch so the end of the strip can slide up in the track. Note: you may need to reach up in the door and pull the window towards you a little to let the strip slide all the way up in the track. I also sprayed mine with some silicon spray to reduce friction to keep it from coming off again
[Modified by Pineapple Devil, 1:26 PM 11/16/2002]
Old Nov 16, 2002 | 09:47 AM
MugenGTR's Avatar
Default Re: Pictures on how to fix your loose window... (Pineapple Devil)
my windows are fine but thanx for the how to anyways
Old Nov 16, 2002 | 09:58 AM
Sima's Avatar
Both of my windows on one of my Integra's has been a little loose for over a year now, but I just haven't had the time and can never remember to fix it. I'll try and get to it next week though. Thanx for the write-up...
Old Nov 16, 2002 | 10:18 AM
Default Re: Pictures on how to fix your loose window... (Sima)
there were a lot of guys on here that had loose windows and i told them how to fix it but they requested pictures so thats why I posted this. apparently this is a known problem like the sunroof chattering.
Old Nov 16, 2002 | 10:22 AM
Smooth-GSR's Avatar
My window rattles only when its not fully closed, does this how to apply to me? The pics a little too close for me, but I think I'll get the idea once the door panel is off.
Old Nov 16, 2002 | 10:32 AM
SonicGSR's Avatar
Default Re: Pictures on how to fix your loose window... (Smooth-GSR)
It applies to you because your glass windows are hitting the metal track,you need to put the rubber lining back in, I had the same problem when I would shut the door with the window partially opened/closed.
Old Nov 16, 2002 | 11:37 AM
yes, this totally applies to you. thats what mine would do before I fixed it. It only rattles when the window isnt pressed agains the top of the door. Once get into the inside of the door you'll see what the picture represents.
you might want to wrap your arm in saran wrap to keep the puddy off you and your clothes. its a pain to get off. especially if you have hairy arms
[Modified by Pineapple Devil, 3:37 PM 11/16/2002]
Old Nov 16, 2002 | 01:48 PM
jdmb18c's Avatar
Thanks man. I too have been having this happen to my car for a while and had no idea how to stop it.
Old Nov 16, 2002 | 04:43 PM
TRAY's Avatar
Default Re: Pictures on how to fix your loose window... (jdmb18c)
Crazy **** I just did that last week. My window still rattles, but not as bad. Im gonna take it apart again sometime this week....
Old Nov 16, 2002 | 05:39 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Pictures on how to fix your loose window... (TrayDay2K1)
so does this rubber thing go in the window track above the window sill, or does it go inside the door, behind the door panel?
Old Nov 16, 2002 | 06:05 PM
vtecdc2's Avatar
Default Re: Pictures on how to fix your loose window... (PatrickGSR94)
just wanted to make sure.. is this what i'm supposed to look at?
Old Nov 16, 2002 | 08:04 PM
Default Re: Pictures on how to fix your loose window... (VTECDC2)
yes thats it and yes its inside the door. that strip fits on the metal track inside of the door
Old Nov 16, 2002 | 08:48 PM
LshatchTurbo's Avatar
New User
good info
deerman2701
Nov 27, 2007 05:59 AM
i-want-a-crx
Oct 13, 2007 08:41 AM
hott-nix
Apr 3, 2005 04:04 PM
EnKidu
Oct 10, 2004 06:43 PM
SIMATIC
Mar 13, 2003 01:10 PM
