Honda CR-V & Element 2WD & 4WD Element & CR-V
2020 CRV-LX
Old Nov 13, 2020 | 04:46 PM
duojet52's Avatar
Default 2020 CRV-LX
I'm leasing a new 2020 crv-lx and was wondering if anyone knew if there was anywhere to see the current tire pressures on the dash. I did the "calibrate" in the tpms settings, but don't see anywhere that shows the pressures. Does it show anywhere or does the low tire symbol only come up? I looked through the book and Honda site and didn't have any success finding it. On the wheel part of the menu where I thought it would show, it only shows the torque that each tire is using.
Old Nov 15, 2020 | 04:21 AM
Jeffdanger's Avatar
Default Re: 2020 CRV-LX
I researched also and you you can't see the individual tire pressure. Honda has eliminated the sensor is each tire stem(look at your stems, they are now brass like old times). They use the wheel sensors to sense small discrepancies in tire speed and when they detect a 10% variance (I think) it lights the tire pressure warning. It does not, however, tell you what tire is low. I think it's a step backward somewhat but I never cared for the aluminum stems with the sensors and really prefer the good old brass ones.
