Help determining what trailing arms fit 2000 Civic SI
Old Nov 13, 2020 | 01:51 PM
jtap's Avatar
Default Help determining what trailing arms fit 2000 Civic SI
I swear I have tried to read the post on interchangeable parts and search and I'm still not quite sure which years and models have trailing arms that would fit a 2000 Civic SI (EM1 chassis). I want to be sure before I pull the parts or buy them. One of mine is bent so I need to replace it so it can be aligned properly.
Am I correct in thinking that all the civic trailing arms with drums will not work?
Will integra trailing arms with disc brakes work? The different chassis codes make me think they might not.
Thanks for help in making this crystal clear.
EDIT:
Looks like they are all the same and you just have to take off the drum/hub unit and put on your disc/hub with the 24mm bolt and the 4 torx 50 bolts.
Old Nov 14, 2020 | 06:16 PM
bumpstick's Avatar
Default Re: Help determining what trailing arms fit 2000 Civic SI
90-01 Integra arms will also work
