I have a 1995 Honda Accord ex vtec 2.2. When I changed the oil and replaced the oil filter I noticed that there was a oil leak escaping oil between the black gasket and aluminum mate at the bottom of the filter 6:00 position. I tried to both tighten and loosen the filter but still leaked. I have found no information on this point so I need help as to the cause. Even tried a second oil filter with same result. Could it be the holder and if so how is this removed?
I’m assuming with the filter off is there anything left on “pad”. If you mean the aluminum mating service the answer is no and the gasket is still attached to filter when removed
COuld it be the wrong oil filter? I think I have had this happen once on this car at the local parts store. It's like it fit, but did a similar thing. Although you have said you used a different filter so that does seem unlikely.
