Looking for info or feedback
Old Nov 6, 2020 | 01:59 PM
Danny Allen's Avatar
Default Looking for info or feedback
I'm working on my eh9 95 civic sedan 5speed, it has a 99 d16y7 because the original owner blew the z6. I've replaced the battery, terminals, and terminal cables, replaced the starter, distributor, spark plugs and plug wires, new alternator, new engine wiring harness, and ecu, it cranks but won't start, I went through all the relays and fuses, I get spark at the coil but not at the plugs. Fuel pressure is good and the injectors work, I replaced some sensors and checked them all. Just tryna get some info or feedback on my situation.
Old Nov 6, 2020 | 07:05 PM
egsleepercivic's Avatar
Default Re: Looking for info or feedback
test the cold and igniter with a multimeter, you should be able to find the procedure on here to test both
I think you meant you have power at the coil put still no spark
Old Nov 6, 2020 | 07:31 PM
muellersfan's Avatar
How are you checking for spark at the 4 spark plugs?
What ECU are you using to the D16Y7?
Old Nov 7, 2020 | 05:48 AM
I'm using a spark tester at the plugs, and yes I'm getting spark at the coil. I'm running a chipped ecu from HA motorsports, I set the chip for the d16y7 and it's an obd1 ecu.
Old Nov 7, 2020 | 09:09 AM
If you have spark at the coil, then focus on the distributor cap, rotor, and plug wires.
Old Nov 7, 2020 | 01:11 PM
tony_2018's Avatar
Fish Twig
I've never seen the lower radiator hose be up that high before....
