94 Honda Accord Wagon Door Control Module?
Does anyone know where this thing lives? I have plenty of information, and videos, showing the electric door lock control module is in the drivers door. All the 1994 Accord sedans I found at the local junkyard have it in the drivers door. I even bought one, in case it might fit my wagon.
But I can't identify the correct module in my 94 Accord Wagon so I can try to repair or replace it.
Any advice appreciated.
On some wagons, the driver's door lock module is in the driver's door (same location) as sedans and coupes.
For wagons with factory keyless entry, look under the driver seat for the keyless door lock control unit.
The control module is not in the door, unfortunately. Does that mean my wagon has factory keyless entry?
I removed the seat and found a black plastic box connected to the wiring harness, plus two more smaller multi wire harness connections (grey plastic, square) that are not hooked up to anything. I disconnected the box and had a look at it, then reconnected it. This caused my ABS light to come on while driving, with a clicking sound from the ABS relay every few seconds. Too bad I disturbed it.
Does anyone know if the central lock control module for a 1994 wagon (under the seat) might be available for purchase?
I've had no luck on Ebay, and would like to seek alternative suppliers. For old Volvo's I would know where to go, but this is my first Honda.
Can anyone recommend reliable used part suppliers that I can check? Any advice appreciated.
