walbro 255 blown fuse
Old Nov 3, 2020 | 01:00 AM
nick266's Avatar
Default walbro 255 blown fuse
i just installed a new walbro 255 fuel pump in my 88 crx and after about 5 minutes of driving it blew the fuse, just wondering if anyone else has had this issue with a 10A fuse, ill try a 15A and see if it blows again shortly.
Old Nov 3, 2020 | 01:46 PM
TacoCat's Avatar
5 Year Member
Default Re: walbro 255 blown fuse
I would not recommend using a larger fuse without knowing what is going on.
How do you have it wired? Do you have a good ground or did you just use a self tapper in some crusty place? Are you using the stock wiring and main relay or an aftermarket relay with a flyback diode? What fuse are you blowing? Is this in tank or inline? Do you still have the stock pump and is it still being powered?
Old Nov 4, 2020 | 12:23 AM
nick266's Avatar
i replaced the stock in take pump with a walbro, ground is good in exactly the same spot as stock and i used all the stock wiring/ relay. fuse number 14 blew which is also alternator and a solenoide valve, so im thinking the bigger pump was just enough to push the fuse to its limits as they draw about 8A.
also found this
https://honda-tech.com/forums/honda-...d-pump-343298/
