Del Sol with bad engine
I have a 93 Del Sol 1500 sohc with 230K miles. it has a stuck valve and is very tired. The body is super, the top and windows are leak free. What should I do? Sell it as is or dump a bunch of money in it? I really don't have the facilities to do a lot. How hard is it to change engines and what motors will fit ? Any advice ? I'm just south of Buffalo NY.
You likely have a D15B (NON-VTEC motor). Either replace it with an identical motor or upgrade. D's and B's series are direct drop in. If you put in a B series, you will need to get a shift linkage from a Del Sol DOHC VTEC. One from an Integra WILL NOT WORK without modification
