Identify Skunk2 cams
Trying to figure out what these cams are. They have "S2 RA02 " plus "AB" directly beneath on the #1 cylinder secondary lobe on the base circle. There's a "B" stamped on the end of one of the cams. VTEC lobes have 0.297"/0.286" lobe lift or 11.6 mm/11.3 mm lift on I/E. And yes, I sent a message to Skunk2 a few days ago but no response yet.
They're advertised as Skunk2 Tuner series Stage 2 cams for B series.
Well I assume due to low staff from Covid19 I would expect longer wait times, you can try and give them a call and they should be able to email you a spreadsheet with ID markings on all counterfeit and authentic SK2 products, they used to have the link on the web site to ID your cams with both older and newer designs but I dont see the link anymore. Or try their IG or Facebook message to try and contact them faster.
Check this link I posted below, Ill be taking off my valve cover tomorrow to replace a stud and can try and take a pic of any markings on my cams as I have the same ones.
https://honda-tech.com/forums/all-mo...kings-2957692/
https://kteller.com/skunk2-camshaft-identification-information/
https://honda-tech.com/forums/sale-1...2864572/page2/
And I got a reply confirming that they are indeed Tuner 2 cams for B series. Thanks for the links, I had checked those out. Apparently a B stamping is now what Skunk uses for these cams.
Nice! I got mine direct from SK2 but they have changed markings throughout the years for their cams.
