Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2007 CIVIC HYBRID
Old Oct 24, 2020 | 11:27 AM
JR1976's Avatar
Icon5 2007 CIVIC HYBRID
please help, I am trying to replace the head gasket in a 2007 Honda civic hybrid, but I need the cylinder head torque specifications, thanks in advance
Old Oct 24, 2020 | 12:53 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 2007 CIVIC HYBRID
Refer to this link for specs.: https://olybrake.com/pdf/fel_pro_torque_specs_guide.pdf
The 2007 Civic Hybrid is a 1399cc engine, see pg 47 for specs. and page 92 diagram # 60 for the cylinder head bolt sequence (i.e., 1, 2, 3 ... 10).
Old Oct 24, 2020 | 03:38 PM
JR1976's Avatar
Thanks for your help, I really appreciated it!
Old Oct 24, 2020 | 04:12 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
You're welcome. Just for clarity.
1. Torque the cylinder head bolts in sequence to 22 FT.-LBS. with a beam-type torque wrench if possible. When using a preset click-type torque wrench, be sure to tighten slowly and do not overtighten. If a bolt makes any noise while you are torquing it, loosen the bolt and retighten it from the first step.
2. After step 1, tighten all cylinder head bolts an additional 130 degrees in sequence.
