Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
What brand caliper?
Old Oct 22, 2020 | 07:27 PM
joenobodyyet's Avatar
10 Year Member
Default What brand caliper?
I have a 2008 Honda Civic LX automatic transmission sedan (102,000 miles). What brand calipers should I get? Any brands to avoid? Is it ok to get remanufactured calipers? I had very premature brake pad wear on both sides. I looked at the caliper and the rubber dust cover seal on the piston is torn on both. On one of the calipers, the rubber boots on the slide guide pins weren't attached to the caliper, just to the pin. The pins were all gunked up although I put fresh sil glyde in there a year ago. Anyway, I don't feel like rebuilding the calipers, and I don't think they're that expensive, so I was just going to get new ones. Do new calipers usually come with everything including guide pins and the rubber boots? I've seen some online that say they don't include the bracket. I guess I can just use my original bracket? Thanks
Old Oct 22, 2020 | 08:53 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: What brand caliper?
Get factory Honda Re-man units... they will cost a bit more than what you find online, but you will be much happier.
Old Oct 22, 2020 | 09:04 PM
10 Year Member
Does coated or uncoated matter? I live in Philadelphia, PA
