96 Accord Injector Box Removal
I just recently purchased some 750cc injectors and it says injector resistor box must be removed. How do I go about doing this? Just pull it out and tie all the red/black wires together? I am stumped. Thanks!
Okay, it looks like what you originally posted. This guy cut the connector off the injector resistor and then tied the red wire with all the black wires; then plug it back into the mating connector.
Most injectors will usually have a (+) symbol on the injector clip or sometimes they may have both (+) and (-) symbols stamped on the side of the injector clip to indicate power and ground wires.
Mine are just stamped 1 or 2. Should I just line them up with the old clips and wire that way?
Yes it was power was number 1 was power and ground was number 2. I finally found the positive (+) inside the pigtail and it matched up!
