Honda CR-V & Element 2WD & 4WD Element & CR-V
I messed with my electrical and now have an AWD light..
Old Oct 16, 2020 | 12:25 PM
Mythic01's Avatar
Default I messed with my electrical and now have an AWD light..
Hey all
I have a 2014 CRV
I messed with a couple plug connectors and the grounding screw/fuses near the driver's left foot area.
Unfortunately this has led to an AWD light coming on solid.
I'm getting codes U0155 F-Can Malfunction, P0498 EVAP CVS Circuit voltage low, P0453 EVAP FTP Sensor high input
Is there an easy fix to this like a fuse i might have removed, a grounding screw which is not tight enough? Or maybe the plug connector isnt in all the way lol...
Thanks
Old Oct 19, 2020 | 11:07 AM
Mythic01's Avatar
Default Re: I messed with my electrical and now have an AWD light..
FML.
Problem was FUSE B6
Owner's manual says it is "Power Windows".
I pulled it for this reason to tap into the circuit....
Why is the owner's manual so vague? It doesn't tell me it also controls AWD control modules...
