Please help - D15B Oil pan gasket
I have a Honda civic '00 LX with an JDM D15B engine mounted and the oil pan gasket it is very bad and leaking oil big time so I need to be replace ASAP but I don't know which one is the right fit part since the old gasket doesn't have a part # , can someone help me out ASAP so I can order it ASAP ? thanks . Also, what can of High-Temp RTV Silicone Gasket Maker can I use ?
VTEC or non-VTEC is a cylinder head issue... this has nothing to do with the oil pan. The displacement difference is due to crankshaft differences... the bore size of these two engines is the same. Since the oil pump, oil pick-up screen, windage tray and rear main seal cover are the same, it is not a stretch to think that the oil pan and gasket would also be the same.
