What Ecu is compatible with the f23a1?
I have a 97 accord swapped with a f23a1 I plan on running really low boost with stock internals, I’ve read around and read that hondata isn’t compatible with the f23a1 so what ecu works for tuning? Let me know thank you
Why not? Give it power, ground, the 5 major inputs.
I bet you could use a SAAB Tronic ECU out of 90's 900 doing the same. Most speed density systems are similar. In the past I used a open source Tronic based SAAB ECU in a Galant turbo that had 2.3L SOHC Hyundai plant.
